Re: super c oil pressure
Posted by riverbend on May 10, 2004 at 06:36:01 from (208.160.34.201):
In Reply to: super c oil pressure posted by g cole on May 08, 2004 at 17:38:19:
Zero is too little. 5-10 psi at idle and 20-30 at WOT should be enough if you are not working the tractor. Anything over 75 psi and your pressure relief valve is not working or something is plugged up.
My H runs at half (the needle lines up with the "i" in oil) at idle and is 1/8" from the end at full throttle. My SC (which I don't believe has ever been rebuilt) idles about 1/4" off the peg and runs at just under half.
An operator's or service manual will have specs for oil pressure.
Post a Followup
: Re: Re: super c oil pressure
