Re: Re: Re: Re: Re: Farmall M
Posted by Wardner on May 10, 2004 at 10:20:43 from (4.138.241.69):
In Reply to: Re: Re: Re: Re: Farmall M posted by Novel Idea Guy on May 10, 2004 at 09:02:06:
It's all in the plumbing. If you exploded the filter, which I assume was on the return side of the circuit, you should have expected another bomb if all you did was remove it. I don't know how you plumbed the reservoir but there should not have been any hardware to separate the flow of the inlet from the outlet in the resevoir. Oil should have been drawn from near the bottom of the liftall and returned to a tee in the filler pipe. This way you could have used both hydraulic systems at the same time with the same oil. I have already done it.
Post a Followup
: Re: Re: Re: Re: Re: Re: Farmall M
