Re: Re: Re: Re: Farmall M
Posted by Novel Idea Guy on May 10, 2004 at 09:02:06 from (148.177.1.212):
In Reply to: Re: Re: Re: Farmall M posted by rustyfarmall on May 09, 2004 at 12:16:38:
If you've got live hydraulics, and the pump belly is being used for a reservior, DO NOT PULL THAT LEVER! We learned that the hard, EXPENSIVE way on my Dad's Stage I Super M back in the '80s. He'd added a live pump and power steering, using the live hydraulics to run the power steering.
First time it was only a hydraulic filter. Second time he split the power steering unit in half, because he took the filter out of the system after it broke. At that point he took the lever right off the old Lift-All unit so the cows couldn't screw it up again.
Post a Followup
: Re: Re: Re: Re: Re: Farmall M
