Re: Farmall A Upkeep
Posted by CNKS on May 10, 2004 at 12:44:39 from (207.178.96.213):
In Reply to: Farmall A Upkeep posted by Christopher S. Dunn on May 10, 2004 at 11:59:11:
IH didn't build any of the carbs for the A,B,C, etc, or the Super A that you have, they are either like yours (MS) or were built by Zenith or Carter. It sounds like you have a fuel flow problem, perhaps caused by crud in the tank, or your sediment bowl could be plugged. The carb has a screen inside the fitting that the fuel line screws into, check that too. Also check your float level, with the throttle body upside down, it should measure 9/32 inch from the gasket to the float. The Woodruff key is 3/16 x 2 1/8, IH part number 66984 D. You can find reprints of the original IH manuals at the website for Binder Books. You need an operator's, parts and service manuals. You will want to keep your I&T manual as a supplement.
Post a Followup
: Re: Re: Farmall A Upkeep
