Farmall Tractors Discussion Board
Re: Upper Bolster / Lower Bushing on H
Posted by Farm-Al Lower bolster bushing on October 26, 1999 at 19:28:04 from (167.142.11.167):
In Reply to: Upper Bolster / Lower Bushing on H posted by John Gatto on October 26, 1999 at 11:11:31:
When I worked for IH dealers we always removed this bushing with A capenose chisel. First you find the seam in the bushing then drive the chisel up between the housing and the bushing, the bushing wiil colapse at the seam and you can remove it. We had A bushing driver to install it with, you could use A heavy flat plate and drive it most of the way, be very carefull to start it streight!! the hard part is the last fraction of an inch, this does require A driver or use the bolster shaft
Post a Followup
: Re: Re: Upper Bolster / Lower Bushing on H
