Re: Re: Re: Re: Sweet Deal Turned Sour; Can someon
Posted by Allan on May 11, 2004 at 18:14:18 from (148.63.132.164):
In Reply to: Re: Re: Re: Sweet Deal Turned Sour; Can someone he posted by Nebraska Cowman on May 11, 2004 at 17:53:04:
LOL!
Well, you're right there. I can sure use all the "thinkin' help" I can get, 'cause I'm the world's dumbest.
Still, I've got nothing to lose 'cause if I road her into town, it will probably cost me close to $1,000 I'd bet, so I'm gonna rip her open tonight here and see if that valve is spraying fluid when it lifts.
It has either got to be leaking off somewhere or the pump is shot; since it holds a load up, one would think that the piston seal has got to be okay.
I'm still unclear on the remotes tho. The guy in at the "Red Shop" says that the remotes and the power steering come off of a piggy-back pump and that the 3 point is all by itself on that big pump. I just dunno.
Thanks for your help,
Allan
Post a Followup
: Re: Re: Re: Re: Re: Sweet Deal Turned Sour; Can someon
