Re: Help on leaking rear axle housing pans
Posted by James in Houston on May 12, 2004 at 17:42:46 from (205.188.116.213):
In Reply to: Help on leaking rear axle housing pans posted by Keith(Texas) on May 11, 2004 at 17:05:08:
You might make sure the bolt hole surface is flat. I have put pans on the edge of a work bench and tapped on the bolt hole surface with a hammer to true them up. If you use silicone make sure the surface is oil free. You might try a little thicker gasket. Good luck
Post a Followup
: Re: Re: Help on leaking rear axle housing pans
