Re: bvpassing cub on-off switch
Posted by Bigdog on May 12, 2004 at 18:50:42 from (204.210.231.154):
In Reply to: bvpassing cub on-off switch posted by carl in nc on May 12, 2004 at 17:52:49:
If you have battery ignition, and a 6 volt positive ground system you can run a jumper from the battery negative post to the negative coil primary terminal. If your system is negative ground, it will be positive post to positive terminal on the coil. Your system should be positive ground if it is 6 volt but many got switched over the years. If it is 12 volt, it will be negative ground so run positive to positive. As usual, when by-passing any component, use extreme caution. You could temporarily stick a toggle switch into the dashboard and wire it. There are only 2 connections.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
