Re: 300U T/A.
Posted by Allan on May 14, 2004 at 03:40:53 from (148.63.132.164):
In Reply to: 300U T/A. posted by Loren on May 13, 2004 at 23:25:19:
Loren,
I bought a tractor with the same symptoms. Mine ended up being that the gizzmo was stuck in high range.
The local shop here says that there are many things could cause this result. That T/A system is kinda complicated and must be adjusted exactly as the book says.
A 300U would probably be a '56, wouldn't it?
Allan
Post a Followup
: Re: Re: 300U T/A.
