Re: 300U T/A.
Posted by dick on May 14, 2004 at 09:35:50 from (4.228.129.116):
In Reply to: 300U T/A. posted by Loren on May 13, 2004 at 23:25:19:
The TA is probably stuck in high range; it may just need a clutch adjustment (EXACTLY according to the book), but don't count on it. If that doesn't work, you still have a useful tractor even if you don't fix the TA - probably for quite some time.
The 300U is set up to accept the toplink for a standard 3-point hitch, all you need are the adapters for the bottom portion of the hitch, which hopefully come with the tractor.
For $500, it's pretty hard to see how you can go wrong, especially if you get the plow and mower cheap. Do spend a few bucks for an Operator's Manual (Binder Books). Good Luck.
Post a Followup
: Re: Re: 300U T/A.
