Re: 300U T/A.
Posted by Red Rider on May 14, 2004 at 21:00:43 from (66.235.45.149):
In Reply to: 300U T/A. posted by Loren on May 13, 2004 at 23:25:19:
Ok Loren let me brefely explain how the TA works. When the TA lever is forward you are in direct drive. When the lever is back your in the low range side. There are two clutches, the main clutch and the TA clutch. When in direct (TA lever forward) the TA clutch is engaged and the whole planatery TA unit rotates turning the input shaft into the transmission. When you pull the lever back you disengage the TA clutch and the rotating power goes through the planatery reduction gear set giving you the lower gearing to the transmission input shaft. So If the TA overrun clutch system was shot your tractor would just plain stop when you pulled the ta lever back. The fact that nothing happens when you pull the lever back tells me that the TA clutch is not releasing for one reason or another. It could be the linkage is out of adjustment. My 400 diesel did that once and it turned out to be one of the bolts that attach the TA pressure plate to the TA flywheel. There is an inspection plate over the TA that you can take off and make sure all the pressure plate bolts are tight. Get you a manuel and adjust the TA exactly as instructed. Let me know what you find.
Home
| Forums
Today's Featured Article -
Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
