super c oil pump
Posted by G Cole on May 15, 2004 at 09:19:45 from (64.91.1.164):
Got the pump apart. The 4 bolts holding the bottom of the oil pump on were loose. It appears part of the gasket was missing and what was left was paper thin. Also the bottom plate of the pump is warped somewhat. Before I took it apart I started the tractor and had 40 psi oil press. In about 5 minutes it was down to 30 psi. Do you think the pump is my problem? Can I use form a gasket to put the pump back together? Does the bottom plate have to be perfect? Also it had some wear in the plate from being loose and the gears had worn in it a little. Thanks
Post a Followup
: Re: super c oil pump
