Re: Normal then Low Oil Pressure
Posted by lee on May 17, 2004 at 07:53:53 from (24.24.95.246):
In Reply to: Normal then Low Oil Pressure posted by rcwilbur on May 17, 2004 at 07:41:20:
Odds are it's worn engine bearings. How many hrs?
You could try a 10-40 oil or a straight weight oil. Is it 20 psi at full rpm or idle rpm?
If it were the pump you probably wouldn't have
55 psi cold.
Post a Followup
: Re: Re: Normal then Low Oil Pressure
