Re: Main Bearings--Necessary to Split Tractor??
Posted by champspa on May 18, 2004 at 16:03:24 from (151.199.216.3):
In Reply to: Main Bearings--Necessary to Split Tractor?? posted by rcwilbur on May 18, 2004 at 05:46:44:
put a hyd.jack under the balancer and an indicator on the frame and apply pressure to the balancer to see how much play is in the crank , mine had .010 it needed bearings and a crank grind
Post a Followup
: Re: Re: Main Bearings--Necessary to Split Tractor??
