Cub carb problem
Posted by Chris on May 18, 2004 at 18:39:45 from (216.135.21.55):
I am working on my grandpa's cub and it only runs with the choke pulled almost all of the way out. It doesn't smoke at all when the choke is pulled out either. I have set the screw on the carb and it runs like new if you pull the choke out. Anybody else had this problem? I have taken the carb apart and cleaned it (including the little passages) it seemed to help a bit for a while (about 2 trips around the barnyard)but now is back to it's old tricks. When you put it under a load it will just slow down and die. I finally got it where it was almost pefect and it started all over again. Anybody know what I should do? Thanks
Post a Followup
: Re: Cub carb problem
