Re: Cub carb problem
Posted by John *.?-!.* cub owner on May 18, 2004 at 20:46:52 from (66.112.43.84):
In Reply to: Cub carb problem posted by Chris on May 18, 2004 at 18:39:45:
Assuming you have a good fuel flow to the carb, you have some loose dirt that is moving around inside it or some dirt in your fuel line/tank that is getting into it. go to your local auto parts store and get some carb soak to put it in for a while, then blow it out good. May also need to clean out the tank good.
Post a Followup
: Re: Re: Cub carb problem
