Farmall Tractors Discussion Board
Knocking in F30
Posted by TMAC on October 27, 1999 at 17:10:59 from (206.74.207.207):
There is some knock from the engine of my F30. I have replaced piston rings and when I tightened the rod bearing, I did them 'snuggly' and inserted cotter pins in the castle nuts. I even removed some shims from two rods for a tighter fit. They all were tight on the crank. So, is this sound normal for such an engine, or will I have to go in and check? On second thought, I guess it would be wise to check anyway.
Post a Followup
: Re: Knocking in F30
