Re: ? about wet oil pan
Posted by nebraska cowman on May 22, 2004 at 04:21:28 from (65.172.142.232):
In Reply to: ? about wet oil pan posted by Alvin NE WI on May 21, 2004 at 18:16:22:
they like to leak around the flange that holds th 3 test cocks. very hard to fix. they were soldered when new but it is imposable to get them clean enough for solder to stick. I have seen lots of them brazed on but then you get it hot enought to melt the solder on the drain plug flange and have to do that too. If you can find the exact spot where it is leaking try cleaning it good and forcing the epoxy weld in the crack with your thumb. Worth a try.
Post a Followup
: Re: Re: ? about wet oil pan
