Re: Re: Re: Re: buying a international 504
Posted by steve on May 22, 2004 at 20:38:08 from (208.19.107.18):
In Reply to: Re: Re: Re: buying a international 504 posted by Wardner on May 20, 2004 at 21:19:00:
went and looked at the 504 again. after some fresh fuel and a battery it started right up. one brake was hung up but that was easy to free.
problem with the hydraulics that raise and lower the 3 pt. and controls the auxilliary hyd. the valve assembly had been removed and taken apart. for what purpose we dont know.looks like it might need a new one, again, not very knowledgable. one question someone might be able to answer, the exhaust on this machine comes out of the manifold and goes directlt down and comes out under the rear axle, the hood looks origanal and there is no hole for the exhaust there. also it has something called a torque amplifier. not sure how it is supposed to work.also found out the machine has power steering. overall i guess it doesnt look too bad, going to check on hydraulic part and probably go for it.
Post a Followup
: Re: Re: Re: Re: Re: buying a international 504
