Re: 15.5/38's on H
Posted by Hugh MacKay on May 23, 2004 at 07:39:58 from (209.226.247.94):
In Reply to: 15.5/38's on H posted by Chris Brown on May 22, 2004 at 17:53:45:
Chris: Depends on you goals. If you are looking for floatation with no added weight it will work quite fine. However if you put the 15.5 on, fill them with chloride, add wheels weights, the H power train will soon be toast.
Another problem will be matching wheels to rims. You will need 300, 350 or 460 wheels to accommodate the double bead rims. If you plan to put the 15.5 tires on the H 10" or 11" rims you'll just be wasteing your time.
Post a Followup
: Re: Re: 15.5/38's on H
