Bad ballast resistor on 12V converted H
Posted by Dave in CT on May 24, 2004 at 20:38:28 from (204.60.45.198):
This is a bit of a newcomer's report but I thought it might help as an archived account of a solution. My '47 H would die or not be able to restart after it ran for about five minutes. It had a ballast resistor in line with a 6V coil. The resistor got hot but the coil did not - which I would assume would be normal. The no-start condition would also appear if the battery was left connected (I usually disconnect the negative ground when not in use) and the shutoff switch was pulled out to the 'on' position. This would heat up the resistor which, again, is to be expected. I pulled the spark plugs and grounded the outside of the plug to cylinder one. When the engine and resistor were cool, I'd get spark; when the resistor was hot, no spark. So I replaced both the resistor and the 6V coil with a 12V coil and now it doesn't die and can be restarted hot. Because the no-start condition appeared with just the resistor heating up, I'm assuming that it was the resistor that was bad. What would be the Volt/Ohmeter test on the resistor to verify this?
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
