Re: Bad ballast resistor on 12V converted H
Posted by riverbend on May 25, 2004 at 17:07:32 from (208.160.34.235):
In Reply to: Bad ballast resistor on 12V converted H posted by Dave in CT on May 24, 2004 at 20:38:28:
You can use your VOM to check the resistor cold and hot, as long as there is no power going through it at the time. Any voltage could be bad for your ohmmeter.
Post a Followup
: Re: Re: Bad ballast resistor on 12V converted H
