Re: Re: Re: Re: Re: Noise in SA final drive, or is
Posted by Hugh MacKay on May 25, 2004 at 07:39:34 from (209.226.106.3):
In Reply to: Re: Re: Re: Re: Noise in SA final drive, or is it posted by Darren in TN on May 25, 2004 at 05:38:58:
Darren: The fill and level plug are the same and is between the two bottom holes on final drive where drawbar can mount on front side. It is a recessed plug about 1-1/4" and can be removed by a 1/2" drive square end.
Pay attention to the noise. A friend of mine didn't and parts within the left final drive came through the casting. Apparently the axle and upper shaft bearings can become so loose that cog teeth ride up on one another. Gets expensive. Jack the tractor rear wheel as it lifts from floor you can see if axle bearings are loose.
Post a Followup
: Re: Re: Re: Re: Re: Re: Noise in SA final drive, or is
