Re: Re: Re: H Farmall charging system
Posted by Bob M on May 25, 2004 at 08:07:05 from (165.170.128.66):
In Reply to: Re: Re: H Farmall charging system posted by Alan on May 25, 2004 at 07:09:05:
Alan – You’ve got the older cutout system. In order for it to work EVERY component (cutout relay, light switch and of course the wiring) must be in good working order.
Since the system has not been charging it’s unlikely your battery got charged backward – and even if it did it wouldn’t have enough stooch to crank the motor. So go ahead and reconnect the battery properly (positive post to ground). Then polarize the generator by momentarily jumpering the two terminals on the cutout.
If the system still does not charge, recommend you get rid of cutout and replace it with a new voltage regulator. It’ll cost less, and it will maintain the battery better than the old cutout system did. And wiring up a regulator is straightforward.
Post a Followup
: Re: Re: Re: Re: H Farmall charging system
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
