Re: front main seal 1466
Posted by K.B. on May 25, 2004 at 20:45:12 from (209.163.30.82):
In Reply to: front main seal 1466 posted by Yellott Canby on May 25, 2004 at 19:44:56:
Shouldn't be too bad if you've got the equipment to handle it. Most guys just put a jackstand under the clutch housing, then unbolt the front bolster from the frame rails, then roll the whole front end/bolster/grill housing/radiator away. After that, you need a puller to remove the vibration dampner, and then the oil pump comes off.
Post a Followup
: Re: Re: front main seal 1466
