Re: Re: Greasing wide front on SC
Posted by riverbend on May 26, 2004 at 19:20:59 from (208.160.33.232):
In Reply to: Re: Greasing wide front on SC posted by scotty on May 26, 2004 at 10:43:55:
My parts book calls that hollow pin a lubrication fitting, like the one on the brace, so I thought it should get grease. The operator's manual does not mention greasing a wide front. After I had used the tractor, I see that there is grease on the front of the pivot shaft.
Post a Followup
: Re: Re: Re: Greasing wide front on SC
