Re: Re: 856 verses 1086 on fuel
Posted by Larry B. on May 27, 2004 at 06:05:43 from (216.240.78.20):
In Reply to: Re: 856 verses 1086 on fuel posted by BFarr on May 26, 2004 at 17:56:10:
If I get started at 10am and run to 7pm, I burn around 25 to 30 gal. depending an if hilly or flat ground. I pull a baler that requires a 90 hp. tractor and in some of thoes hills I bale it takes about every horse. I bale 80% of the time in hi first gear or in real steap hills low four.
Post a Followup
: Re: Re: Re: 856 verses 1086 on fuel
