Re: International 434
Posted by Ben in KY on May 27, 2004 at 13:10:33 from (192.76.82.90):
In Reply to: International 434 posted by John on May 27, 2004 at 09:38:45:
Sounds like several things.
Clean the carb.
flush the cooling system and change thermostat, check belts and tension.
Check points plugs and timing.
Check hydraulic fluid for water/foaming/low level, change if foamy or milky.
Clean hydraulic suction screen.
PTO problem might be a bent PTO engagement lever not allowing the PTO to fully engage.
Good luck.
Post a Followup
: Re: Re: International 434
