Loose CLutch
Posted by Bill on May 29, 2004 at 14:24:46 from (69.177.15.19):
Hi All
I am having a problem with my loboy 154. I try putting the tranny in reverse and noticed lots of grinding so I put into 1st then bach into reverse let off the clutch and nothing. I took a look at the clutch and noticed than when engaged and in gear the clucth turns but it does not turn the drive shaft. Also the clutch seems kinda loose-is there supposed to be a little play? The tracor ran fine with no slipping prior to this. Can this be an adjustment issue?
Thanks
Post a Followup
: Re: Loose CLutch
