Re: Re: Re: farmall m firing order
Posted by TomH on May 29, 2004 at 17:26:06 from (206.101.85.87):
In Reply to: Re: Re: farmall m firing order posted by Jamie Stratton on May 29, 2004 at 14:09:03:
Here's another try. Pull the spark plugs from the cylinders and put your thumb over the #1 hole (closest to the front). Get someone to crank the starter or turn the engine by hand until you feel air pushing your thumb off the hole; that's when the piston is on the compression stroke. Now look at the big pulley at the front of the engine, right below the govenor you should be able to find the timing mark close to the pointer, move the pulley until the mark lines up with the pointer (if all of the spark plugs are out you can crank the engine by turning the fan by hand). While you're turning the engine take a look at the distributor and watch which way the rotor turns. The engine is now where the spark should fire #1. Loosen the distributor and turn it until the points just open as it climbs up the cam (remember which way the rotor will turn), that's when it will fire. Now put the rotor on the distributor and see where it's pointing, the connector on the distributor cap where the rotor is pointing is the one you want to connect to #1 spark plug, then connect the other plug wires in the firing order.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
