Re: Re: 856 blowing water out radiator yet. help!!
Posted by Larry B. on May 30, 2004 at 14:17:44 from (216.240.78.39):
In Reply to: Re: 856 blowing water out radiator yet. help!!!! posted by Tommy D6-8U on May 30, 2004 at 13:56:27:
It's start's blowing water as soon as it starts. With the cap off, as soon as it starts it's like you put a air hose in the bottom of the radiator. As soon as it starts also, there's like a small trace of steam coming out the radiator with the cap off. We put a pressure tester on it and it will build up 20psi in about two min. and into the red on the tester but the tractor does not ever run hot even two gal.low in the radiator. I have a 10 lb. cap on it and useing it six to seven hours it will loose 2-2/12 gal.
Post a Followup
: Re: Re: Re: 856 blowing water out radiator yet. help!!
