706 hyd, question,
Posted by chris on May 31, 2004 at 05:43:40 from (199.35.235.237):
my 706 while under load if you hit the brakes, turning or if one wheel is spinning the ta will let loose like you shoved the clutch down when you let off the brake it will jump out from under you, my question, what pump runs what, what does the front pump run and what does the back pump run
Post a Followup
: Re: 706 hyd, question,
