Re: farmall m stuck pistons
Posted by Pat Rivers-Bowerman on May 31, 2004 at 19:21:57 from (142.166.251.178):
In Reply to: farmall m stuck pistons posted by pedro on May 31, 2004 at 12:09:29:
The pros have the same grief too.
Was just by an engine re-builder's shopin a dairy-town where I have my IH bits in.
They had the two-cylinder block from a green tractor [John Deere 720 - am I allowed to mention that, here ?]
It had stood out in the Back Forty for 17 years. Its new owner, a collector, had managed to get one huge piston out; the other was not shifting at all, so he brought it in.
Anyhow, the shop has it in a big press, with a big piece of round stock on piston crown, liberal doses of penetrating oil and gingerly brought hydraulic pressure up to 2,000 psi.
The BIG aluminum piston had 4 rings - but was grooved for 6. And the oil control ring was mounted on the skirt below the gudgeon pin - so there has to be plenty to stick fast.
Not shifting as yet - it's a solid bore [eg: no liner] so a cracked block would be fatal ....
Will let you know how they make out - in event, it may work here.
Regards
Pat from New Brunswick
Post a Followup
: Re: Re: farmall m stuck pistons
