Re: 560 hydraulics
Posted by Joe Evans on May 31, 2004 at 20:02:01 from (209.41.235.128):
In Reply to: 560 hydraulics posted by bryan on May 31, 2004 at 17:30:47:
bryan: since you rebuilt the regulator block, the only thing left to do based on the symptoms you describe is to replace the pump.
If you overlooked the O-ring seal on the regulator piston during the block rebuild, it will not produce the symptoms you describe IF your pump is A-ONE.
Steel Wheel Ranch has rebuilt pumps for $250. They are a breeze to change out--IMO one of the good things IH did for pump serviceability. Just went through a hydraulic system rehab on our 460. For a complete report, go to our web site and read about all the hair-pullin' I went thru to resolve a bad hydraulic system. You'll find a link to Steel Wheel Ranch there, too.
Post a Followup
: Re: Re: 560 hydraulics
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
