Re: 1206 starts hard
Posted by the tractor vet on May 31, 2004 at 20:05:07 from (216.196.13.92):
In Reply to: 1206 starts hard posted by Joe on May 31, 2004 at 19:34:49:
The 806 and 1206 were vary good starters , it could be that the starter is in need of a rebuild as the bushings are probably woren and it could be draggen on the fields or the injection pump is low on cranking pressure or that the engine compression could be down from the valves being resessed in the head to far and this will cause low compression or the injestors are not cracking at the wright opening pressure. or it could be in need of a major overhaul.
Post a Followup
: Re: Re: 1206 starts hard
