Re: Non-corrosive alternatives to calcium cloride
Posted by David B on May 31, 2004 at 20:07:48 from (65.173.238.146):
In Reply to: Non-corrosive alternatives to calcium cloride in t posted by Dave in CT on May 30, 2004 at 23:46:12:
Personally, I would drain the fluid out, and buy some original IH wheel weights. The weights are all over the place, I bet you could find some locally. Plus, they won't freeze.
To get the fluid out, we like to pull the core out of the stem, and press down on the tire with the front end loader. This is easy to break tires down, and you don't have to watch fluid come out all day.
Good Luck
Post a Followup
: Re: Re: Non-corrosive alternatives to calcium cloride
