Re: farmall m stuck pistons
Posted by RST on May 31, 2004 at 20:41:23 from (66.24.123.15):
In Reply to: farmall m stuck pistons posted by pedro on May 31, 2004 at 12:09:29:
Get the torch and cut them out. No waiting around. You may loose a piston rod or two but it's quick and dirty. Time is money. Good luck!
Post a Followup
: Re: Re: farmall m stuck pistons
