Re: farmall m leaks, misses, and sounds like crap
Posted by Carp on June 01, 2004 at 18:45:02 from (209.240.23.74):
In Reply to: farmall m leaks, misses, and sounds like crap at i posted by Jamie Stratton on June 01, 2004 at 15:42:33:
That's a lot of questions. First of all, if the tractor has set a while without being used, a lot of leaks are to be expected. All you can do is fix them one at a time.
It is normal for the hole in the bottom of the carb to leak after being choked. If it stays wet when the tractor sets for a period of time, you may have a leaking needle valve or improperly set float.
Two things on the miss. If it is constant all of the time and does not change with throtle setting I would check the valve clearance. A really tight or loose valve will make the engine run uneven and sound kind of like a miss. The other possibility would be the carb or manifold gasket leaking.
Best thing you can do is get the manuals and attack the problems one at a time with info from here if needed. None of the problems you mentioned are hard or terribly expensive to fix Normally :)
Post a Followup
: Re: Re: farmall m leaks, misses, and sounds like crap
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
