Re: super A horsepower
Posted by Joe Evans on June 02, 2004 at 11:31:00 from (209.41.233.198):
In Reply to: super A horsepower posted by patpeery on June 02, 2004 at 11:03:22:
That's a good question! The A gas tractor Nebraska figures are 18.34 MBHP and 16.32 MDBHP. IH's 'corrected' figures for the A gas are 19.06 and 17.35 respectively. These figures are at 1400 rated RPM.
The Super A was not tested at Nebraska. Instead, Nebraska published figures for the Super A using the A test figures.
I have read where the Super A in reality has more horsepower than the A because some (all?) of the Supers run at a higher rated RPM, therefore it stands to reason the Super A would be a bit stronger on the dyno.
Don't forget about the Super A-1. That one's a mystery to me, too.
I have not run across any published data explicitly saying exactly what the Super A is supposed to put out. This question should generate a lot of feedback as it seems the A/Super A is the most talked about model on this forum.
I will wager a doughnut that Harold H has the appropriate information.
Post a Followup
: Re: Re: super A horsepower
