Re: anyone heard of a H with engine oil dipstick?
Posted by rustyfarmall on June 03, 2004 at 05:46:45 from (216.248.75.143):
In Reply to: anyone heard of a H with engine oil dipstick? posted by red reaper on June 03, 2004 at 05:15:40:
As far as I know all Hs had the area for the dipstick, it just was not drilled out. It would be a fairly simple matter for someone to drill a hole and then install a dipstick. There may even have been an aftermarket kit for this purpose. Also, I don't know for sure but I think some of the stationary power units may have been equipped at the factory with a dipstick. You may want to compare the casting codes and serial numbers to determine if the engine is original to the tractor.
Post a Followup
: Re: Re: anyone heard of a H with engine oil dipstick?
