Re: Starting Problems- Farmall C123 Eng.
Posted by Randy in NE on June 03, 2004 at 08:10:58 from (216.58.237.20):
In Reply to: Starting Problems- Farmall C123 Eng. posted by Jerry in WA on June 03, 2004 at 08:04:08:
You said that the rotor is lined up with TDC of #1. Is it on the compression stroke or the exhaust stroke. The crankshaft turns 2 revolutions for each turn of the distributor. Are the wires on in the right order? You can pull the distributor cap and turn the motor over to check the direction of rotation for the rotor. More than one person has put them on for the wrong rotation of the rotor. Just a couple of things to check.
Post a Followup
: Re: Re: Starting Problems- Farmall C123 Eng.
