Starting Problems- Farmall C123 Eng.
Posted by Jerry in WA on June 03, 2004 at 08:04:08 from (67.136.134.40):
I have a mid-60's Farmall 240 Utility Tractor with a C123 engine. When I originally got it, it was running, but just barely. I got it home, and started cleaning out Hornet's nests from the air cleaner, the exhaust, and cleaning out 2 years worth of dirt leaves, etc. I pulled off the Zenith-Bendix updraft carb, and after opening it up, decided to take it to the rebuilder. I checked the walves to make sure that they were opening and closing all the way. I pulled the distributer and cleaned out the hardened grease out of the centifical advance weights, re-gapped the points, and re-installed it making sure that I was coming up on #1in the firing order. When I got the carb back, I re-installed it, charged up the battery, drained and put in new oil in the crankcase. I drained and put new gas in the tank, getting ready for the big moment. When I tried to start it, the following happened. It turns over pops a couple times, then backfires through the carburetor. I have tried adjusting the timing by turning the distributor. It doesn't help. I have pulled the #1 plug, brought it TDC, and checked the rotor to make sure the distributor is lining up ok, and it seems to be right on as the timing mark lines up on the pulley. Now I haven't pulled the head, because the fellow I bought it from said he had the engine gone through before he parked it, and the valves and springs from the top side look clean as if they were done before he parked it. (No build up or discoloration, all clean and shiny) I also checked each spark plug with an in-line tester, aand I am getting spark to each plug. If anyone has any suggestions or ideas, I could sure use them, because I am stumped. Is there something I have missed? Any help would be greatly appreciated.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
