Re: Farmall M with torque amplifier - questions
Posted by jal-SD on June 03, 2004 at 10:13:32 from (64.68.183.24):
In Reply to: Farmall M with torque amplifier - questions posted by Duke Duclos on June 03, 2004 at 09:14:42:
Filter is easy. Go to your local parts or C-IH store & ask for a filter for SM-TA. They should have one in stock. Make sure you get a gasket with it. Remove the drain plug @ bottom of filter housing, have an empty soup can ready to catch the old oil. Crack the large bolt on the top of the filter to allow air to enter. Let it drain until all drips stop. Remove the bolt, wiggle the canister loose from the bottom, remove it taking the filter out at the same time. Check to make sure you know what direction the filter goes back in. Throw away the old filter, clean everything up & remove the old gasket from the groove where the canister sets into the housing. It'll probably come out with great difficulty, if its been in there a while. BE SURE YOU GET IT ALL. A seal pick works great to get them out. Wet the new gasket with clean oil & install it in the grove, put in the new filter, install the canister & long bolt & tighten appropriately. You are now good to go, as soon as you put oil in the crankcase. Check for leaks after you run her for a few minutes. They'll leak a little once in a while, usually all it takes is to tighten the bolt a little more IF YOU GOT ALL THE OLD GASKET. Be sure to change oil in the can on the bottom of the air cleaner, they are usually about 1/2 full of dirt, make sure you scrape it all out. Takes the same thing you use in the engine if its multi-grade or 10W if you use straight weight. (My $0.02 worth. jal-SD)
Home
| Forums
Today's Featured Article -
A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
