Re: oil on brakes Super A
Posted by Haas on June 03, 2004 at 18:02:01 from (12.65.42.116):
In Reply to: oil on brakes Super A posted by Deane on June 03, 2004 at 15:36:29:
While you have it apart, replace both the final drive seal and the transmission (differential) seal. Transmission seal is IH number 288864 R93, National 410060 SSR. Final drive seal is IH 71597 C91 (new number), national 410083. If you replace the final drive seal, the drum brake drum must come off and the pinion shaft out, so you'll also need gasket IH 1342398 C1, which is for the cover on the final drive over the pinion shaft acess hole. Pretty good job to get the final drives off to rework the brakes and replace all this.
Post a Followup
: Re: Re: oil on brakes Super A
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
