Re: Possible Coil Problem on Farmall A
Posted by Dave in CT on June 04, 2004 at 09:36:56 from (204.60.45.247):
In Reply to: Possible Coil Problem on Farmall A posted by Christopher S. Dunn on June 04, 2004 at 08:47:57:
I'd check the coil cold and then after it starts to stall out - wait until it is at its worst - like when it won't start again. To check the coil pull the center wire out of the distributor and hold (or clip) the free end of the wire about 1/16" to 1/8" away from a good ground. My H owner's manual shows a method in the timing section of clipping this wire under the distributor cap clip. Clip it so the end of the wire is 1/16" to 1/8" away from the bolt on the side of the distributor where the wire that goes to the positive pole on the coil is attached. If you have help you can hold it in this position with some well-insulated pliers and have the other person turn the engine over. Turn the engine over. When cold you'll probably see a bluish-white spark. When you do the test after it starts to run bad, if the coil is bad, you'll probably see a yellowish spark or, if it's died, no spark at all. Hope this helps. Let us know what happens.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
