Re: 966 PTO Problem
Posted by Pa on June 04, 2004 at 13:16:58 from (65.171.201.104):
In Reply to: 966 PTO Problem posted by Poor Farm Jim on June 04, 2004 at 11:50:48:
Allan has got it right. There is also a coupler that you will want to be sure doesn't fall into the trans. It connects the PTO to the input shaft from the motor. They can be tricky to get back in, but with a little patience you should get it. The PTO is heavy so you should have someone help you lift it out and in. Hope it helps
Post a Followup
: Re: Re: 966 PTO Problem
