Re: Re: Re: Possible Coil Problem on Farmall A
Posted by john *.?-!.* cub owner on June 04, 2004 at 19:07:53 from (66.112.43.53):
In Reply to: Re: Re: Possible Coil Problem on Farmall A posted by Christopher S. Dunn on June 04, 2004 at 16:38:50:
You can get a generic 6 volt coil at most auto parts or farm supply stores. It may look different from yours but will work. Don't forget that since the system is still 6 volts it probably is also + ground, so the + terminal of the coil will connect to the lead going to the distributer, and the - terminal goes to the ignition switch.
Post a Followup
: Re: Re: Re: Re: Possible Coil Problem on Farmall A
