Re: 560 diesel start up
Posted by Aces on June 05, 2004 at 08:28:52 from (207.223.245.178):
In Reply to: 560 diesel start up posted by bryan on June 04, 2004 at 19:46:06:
Bryan you will need to use the glow plugs, but on a rebuilt engine I crank it over a few times then set the valves at .020. Then I crank the engine untill I have smoke out the exaust, if you don't have smoke the glow plugs aren't going to do any good why use the battery on the plugs, if you don't have smoke bleed the fuel system, when you get smoke then heat the plugs it should start.
Post a Followup
: Re: Re: 560 diesel start up
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
