Re: 240-U Transmission Hydraulic Case
Posted by Stan(VA). on June 06, 2004 at 05:28:58 from (208.59.156.177):
In Reply to: 240-U Transmission Hydraulic Case posted by Jerry in WA on June 05, 2004 at 22:02:38:
If you're draining the tranny case, it uses gear oil and the drain should be under the differential. If you're wanting to drain the hydraulics, the reservoir is the torque tube and there should be 3 drain bolts pointing out one side on the bottom of the torque tube.
Stan(VA).
Post a Followup
: Re: Re: 240-U Transmission Hydraulic Case
