Re: H STEERING SHAFT U JOINT
Posted by rustyfarmall on June 07, 2004 at 18:21:09 from (199.120.81.213):
In Reply to: H STEERING SHAFT U JOINT posted by JON on June 07, 2004 at 18:15:34:
It depends on what year your H is, that same u-joint is bad in my 1940, and a rebuild kit does not exist, anywhere. If your H is a later model, you can get a kit fron Case-IH. In the case of the early models, you replace the entire joint.
Post a Followup
: Re: Re: H STEERING SHAFT U JOINT
